U310BT/Amplifier/Battery Question
By dillback · Dec 15, 2010in Problems/Troubleshooting💬 3 posts👁️ 2,687 views
Posted Dec 15, 2010 · 23:52 UTC#1
I have an amp hooked up to my U310BT to run a 12" subwoofer
I remember in my old car (same amp, different Deck) when i turned off the Deck, the amp turned off also. What i have noticed with the U310BT is even if you turn off the music source, the amp still stays on. Now that it is winter, i start my car and let it warm up for 10-15 mins before i leave. Is the amp going to drain my battery? i dont know if the car just idling is enough for the alternator to keep the battery charged.
Posted Dec 16, 2010 · 03:08 UTC#2
Your battery should be fine.
Posted Jan 03, 2011 · 12:53 UTC#3
You'll be fine. The alternator can handle it.
