Thanks ducatiboy. I'm going to head out to Radio Shack and get the stuff.
I purchased a couple of the 5v regulators yesterday - but just hooking that inline is not the "right" way. I'll show that datasheet to the folks at the store.
Just out of curiosity, what regulators did you buy? You want to be careful about the input voltage tolerance, some 5V regulators will only take 10V as an input voltage, some take up in the 30V or 45V range. Also look at the amount of current the regulator can put out.
For this application, I would generally say to stay away from packages that look like this:
and
And go with one that looks like this:
or
Those will have higher current ratings and generally higher voltage tolerances. Better safe than sorry. With the way this is hooking up to the supply of the Z1, not the car's electrical system, you should be pretty safe. But the remote out is rated for 300mA. I don't know how much the amp in the vehicle draws, I never measured it. But the second set of pics is rated for 1A, the first set usually is 100mA. I hate putting in something weaker in the line, so I like overkill just in case.
Here is a pic I have of a part which was "undersized for the application".
http://www.avic411.com/forum/viewtopic. ... 30&start=5
When in doubt, check the data sheet specs for the parts you are putting in to your vehicle!
