Steering wheel controls
By netman · Dec 20, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,478 views
Posted Dec 20, 2010 · 06:07 UTC#1
I have an Avic Z3 installed in a 2007 Silverado. In the past couple of days the steering wheel controls will not allow me to change the source or go up or down to next track. The volume works fine though. It has done this on and off for five days now. One day it works and the next it does not. When I push any of the controls there are XM radio hilites on my odometer. Any ideas as to what may be causing this? Thanks.
Posted Mar 16, 2011 · 08:49 UTC#2
A wire probably came loose. Try checking all your connections. If that's ok, I'd try reprograming your steering wheel module.
Posted Mar 16, 2011 · 14:42 UTC#3
I had a similar problem except the volume would work sporadically. I ended up having to replace the SWI-PS unit.
Posted Mar 16, 2011 · 18:53 UTC#4
Garret, I have my track change, mode and volume all working, but is there something for the voice command button and or pickup and hangup phone calls ? I drive a Lexus RX400H
Posted Mar 16, 2011 · 19:17 UTC#5
On mine, only the volume down was failing...
