Obviously the best place for a nav antenna would be on the roof of the vehicle, however this is not always the easiest place to install nor does it accent the look of a vehicle with an unsightly wire. You can install a nav antenna under any dashboard that doesn't have metal in it, and it will work fine. The other route is to use a factory or aftermarket drill in type antenna as in the GM, Audi or VW vehicles. I purchased a couple of the GM 3 band antennas(XM, GPS and cellular) and installed them, the only catch is you need wire extensions for the portion of the antenna that you want to use. They looked awesome once installed, you can find them at
www.gmpartsdirect.com, you need two part numbers: Base 25773456 $88.19 , $176.39 list, Mast 25758073 $7.55 , $15.09 list. Then all you need are some extensions(contact me, I can custom cut you any length of RG-174 with the correct connectors attached)and you'll be all set!
