Hi I just had my z110bt installed today in a 2003 Lincoln ls with the video bypass and a PAC wrip remote interface and everything works but the beep sound,the phone sound, and the nav voice. After spending 1 hour messing with it I realized that the voice on the phone works but extremely low to where u can not hear it. I tried searching but it's late and I'm tired. Any help is much appreciated. And please don't post a link to another thread because the other threads with the same issue did not seem clear as to what the problem/solution is. Thank you
Please help
Page 98 of the Z110 manual. That clear enough for you?
Other possiblilies, but with the info you've provided, that is where to start.
Check your fader and/or if your front and rear outputs are switched.
RonS I already did that. I have it installed with 2 jl audio amplifiers a hd600/4 and a hd750/1. Like I said everything works fine it even plays my phones ringtones but no beep sound nav voice or phone voice. The people I call can hear me perfect but I can't hear them.
Then the amps are connected wrong. Voice only goes to the front speakers. Switch the pairs of RCA cables going to your front amp.
I switched the rca's today and still no solution I'm getting annoyed with this issue. My installer has no idea wat it could be. Anyone have anymore ideas?
Vblue42 I no u got the answer help
