Am looking to upgrade to the 700bt. I have found a cheap one buts American. It has the latest firmware update and bypass etc. But, if I buy it then how do I install or use European maps?
Posted Dec 27, 2010 · 07:55 UTC#1
Bump
well you will have to remove the US maps and load UK maps, the bigger issue you will have it that you guys use different radio freq's so the radio will not work there, also there is a difference in video signals, so any thing you hook up to it (such as an Ipod) will need to be switched over to NTSC (not possible on every device)for the video to show up.
