Yes, I'm a Noobie. I purchased a used truck (03 Excursion/7.3d/Eddie Bauer) that had the X910T already installed. I downloaded the user manual and have actually *used* it. Overall, I really like this system (as I expect most on this forum do) and it's amazing what all it can do.
My iPhone4 connected right up with the BT and it works great. I tried to upload the contacts and ran into the 1,000 number limit (as documented by VBLUE42), so I'll just use the phone.
I have three questions:
1) I have the message "System detected improper connection of Parking Brake". I assume this related to the bypass done during install (by BestBuy). Should I consider doing anything about this?
2) I've looked through all of the "Pandora" problems and did not find a solution for my problem. I have downloaded the "PandoraLink for Pioneer" as explain in at least one post. I start the link app, then the Pandora app, plug in with either the USB or the front jack (based on the manual, it appears it is an input app) and I get no sound. I have no stored music, as I find Pandora is fine for me. The USB option for AV Source is grayed out. Any suggestions?
3) I'm a Sirrus user, primarily because of the NFL coverage. I know I can have the module installed and use Sirrus directly, but just wanted some input from users who use it. Is it worth it?
TIA,
LarryB
