GEX-p20HD on X910bt
By chood711 · Dec 29, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,014 views
Posted Dec 29, 2010 · 05:47 UTC#1
Whats up guys,
I attempted an install of the p20hd on my x910bt in a 06 cobalt ss and i couldnt get any sound. do i need to hook up that antenna wire for this to work because that is the only thing i didnt hook up that the manual mentioned. the reason i didnt hook it up is that my car has no power antenna. any recommendations or opinions? thanks in advance
Posted Dec 29, 2010 · 05:58 UTC#2
what antenna wire you talking about?
Posted Dec 29, 2010 · 06:45 UTC#3
in the wiring diagram it has a head unit with a wire coming out and
it says "blue/white
Control signal is output through blue/white cable when pioneer
head unit is turned on. Connect it to the vehicles auto antenna
relay control terminal. if the vehicle is equipped with a glass
antenna, connect it to the antenna booster power supply terminal
Posted Dec 29, 2010 · 07:58 UTC#4
yeah u dont need to connect that wire if you don't have a motorized antenna. Are you locking in to stations?
Posted Dec 29, 2010 · 17:31 UTC#5
i got sound out of it now..i think i have a ground loop problem though. when ever i unplug the antenna out of the back of the radio my subs make loud pulsating tones.
