F500BT upgrades? (US model)
By whalepirot · Dec 30, 2010in Hacks/Mods💬 22 posts👁️ 8,841 views
Posted Dec 30, 2010 · 08:24 UTC#1
Just got this cool unit and did the official firmware BT updates from Pioneer. New w/ this unit but am thrilled that I got the testmode booted to a WinCE screen.
1) will this unit allow keyboard or mouse control via the micro USB? just touch?
2) do the 3.0 or 3.1 updates work on the 500 and offer, say the all-in-one mods posted here by one of you generous geniuses? most troublefree version and thread to effect it?
3) map upgrades; any traps there for UC only?
Be kind. I have read a lot of posts and have trouble keeping it all straight when folks don't post any detail like which unit or firmware, etc. they run. thanks.
Posted Dec 31, 2010 · 18:42 UTC#2
I got my F500BT 3 weeks ago and it comes with 2.06 which is very stable. AFAIK:
1) USB keyboard will work but very few discussions on this.
2) From my research on the 3.0, it's a Europe release only and no US 3.0 for F500 (latest is 2.06). Some people try the 3.0/3.1 and most have small issues. I stick with 2.06 and use the new iGo in 3.0 with 2010Q4 US maps
3) You can find speedcam file from other place, I got one from other iGo related site.
I also tried the OS mod but I cannot got the F500 to recognize the new WINCE image and the flash function always stuck at 100% reading (no writing).
Posted Jan 05, 2011 · 19:47 UTC#3
I upgraded all three of my units with following instructions and it worked perfectly for me.
You need only a single SD card, at least 2GB in size. Copy the entire contents of the RAR file except for the WINCEIMG.BIN and WINCEIMG.CKS to the root of SD card. For the two WINCE*.* files, I had to use the one I download from this link. http://www.rapidshare.ru/1206567
The one that came with the FX3.1 would not allow me to boot after I flash WinCE>
You will need to go to the folder APL2\iGo\ and delete the current sys.txt and rename sys_749UC.txt to sys.txt.
You can delete the other sys_*****.txt files and any maps that you may not use. You may need to do this because the F500BT may not the capacity for all the new maps.
1. Insert SD card (minimum 2GB) with testmode into AVIC and turn it on.
2. Backup My Flash Disk by copying
3. When the pioneer logo comes up, press and hold the power and reset buttons at the same time until the blue service screen comes up then release power and reset buttons. (you should see Press reset again to reset but don't press reset yet)
4. Press in this order MAP, MAP, MENU, ENTER (down on joystick), MENU then ENTER. (each button press will show an asterisk at the bottom center of the screen). If the correct combination is pressed, then a menu with options pops up.
5. Select Wince Upgrade with Format (SD)
6. At the bottom center will first display the status of reading in the file. It then will clear the message and will show the status of writing the file. Then it will do a quick test. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in (remember to reset you have to press and hold both power and reset buttons.)
7. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "My Flash Drive" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. (It will the copying will take 140min but will only take about 20)
8. On the desktop should be an icon to RESTART the unit. Double click on that to restart, make sure you take out the SD card so normal boot process happens.
8. Select your language and voice options.
9. Enjoy FX3.1 :)
Make sure to upgrade your unit using free update from Pioneer first, then follow as these steps are.
There is minor update on following steps.
3. Press and hold the power and reset buttons at the same time until the blue service screen comes up (No need for waiting pioneer logo) then release power and reset buttons. (you should see Press reset again to reset but don't press reset yet)
5. Select Wince Upgrade with Format (SD) (Press and hold reset to enter selection, press reset quickly to toggle through options.
Also upgraded with 2010 maps and tried all mods from completed mods/themes forum and worked flawlessly.
Edited Jan 05, 2011 by urtruelove78
Posted Jan 06, 2011 · 19:36 UTC#4
No luck, it always stuck after 100% read. I gave up and settle with 2.006. My unit comes with 2.006 installed and is a refurbished unit. I really want to try my mod WINCE... well, may try to pick up a cheap one again later.
Posted Jan 14, 2011 · 02:02 UTC#5
I tried it, but I mass up with sys.file. It is gone.
How did you get back when the fx3.1 would not allow you to boot after you flash WinCE?
Posted Jan 14, 2011 · 22:24 UTC#6
When you say you messed up sys.txt are you able to boot into testmode or no.
Do you see any screen at all when you try to start the unit?
Posted Jan 15, 2011 · 04:57 UTC#7
Yes, I got the testmode.
I just copied the files into the My Flash disk folder when it just showed me testmode(window).
After dinner, I came back.
I totally forgot about "sys.txt" part.
Unfortunately, I realized your direction after I power off it
, and then I can not get into the testmode(window) anymore.
Edited Jan 15, 2011 by jacceci
Posted Jan 17, 2011 · 17:46 UTC#8
Let's go one by one.
(1)So you upgraded to 2.06 free pioneer update.
(2) Upgraded Win CE
(3) Went into testmode and copied files from 3.1 upgrade but forgot to change sys.txt?
What happens now.
(1) You put sd card with testmode 2.3 into avic
(2) try to start unit
(3) what happens here?? --> Do you see avic boot into any logo or won't turn on at all?
Or it boots but won't go into testmode
Posted Jan 18, 2011 · 00:42 UTC#9
First part (1)(2)(3) yes,I did.
I could get into testmode just one time. After that, I couldn't get into it.
Second part
(1) Yes, I put sd card with testmode.
(2) (3) Yes, I can turn on it, and I could see the logo, and then it turns black screen until MBR fomat in service mode because of another mistakeî
I can't get into testmode.
Now, I can turn it on and see only black screen.
Edited Jan 20, 2011 by jacceci
Posted Jan 18, 2011 · 06:14 UTC#10
Try downloading mod from following link and see if you can get working unit.
Diaftias hybrid mod
Posted Jan 18, 2011 · 06:16 UTC#11
And please follow steps as described...if you don't understand certain part..don't just go ahead and try to mod unit. Instead ask for help and somebody will help you out.
Else you will have bricked unit.
Posted Jan 18, 2011 · 13:06 UTC#12
Thank for your helpî”
Posted Jan 18, 2011 · 19:36 UTC#13
Did it work?
Posted Jan 19, 2011 · 05:53 UTC#14
Did it work?
It doesn't work for me because the mode requires 3.0 firmware, but I can get into testmode now after I downgrade wince.
When I upgraded wince, I couldn't get into it again, so I downgrade wince again.
I copied my original files into my flash disk, and then I turned on the power.
I can see black screen and go into main screen when I press the menu button.
However, the buttons don't work at all. :?:
Edited Jan 19, 2011 by jacceci
Posted Jan 19, 2011 · 18:53 UTC#15
Thank you for your help!
It finally works again with my original back up files!
"My F500bt back :razz: "
I followed two resources Reboot fix
and MBR format recover.
I will try fx3.1 again tonight. :rolleyes:
Posted Jan 19, 2011 · 19:18 UTC#16
You probably need the updated testmode files.
Posted Jan 19, 2011 · 21:53 UTC#17
Yep. That's why i asked in earlier post if he is using testmode 2.3 which is for 3.0 upgrade.
Posted Jan 20, 2011 · 04:16 UTC#18
I did it! :D
Thank you so much!
Posted Mar 04, 2011 · 01:25 UTC#19
What is the advantage to upgrading igo, is it just for newer maps?
Posted Apr 23, 2011 · 17:48 UTC#20
Hello
after months of researsh, finally I did update my F500BT US version from V2.06 to V3.0
Try to follow exactly this thread #381 http://avic411.com/index.php?/topic/27807-fx31-complete-firmware-image/page__st__375
the link from raoidshare.ru for WINCEIMG.BIN and WINCEIMG.CKS is not working
I upload the file on:
http://www.mediafire.com/?dem8wi4s7d5h6cu
http://www.filesonic.com/file/827534291/WINCEIMG_F500_6.5.0.6_for_3.02.rar
https://rapidshare.com/files/458834242/WINCEIMG_F500_6.5.0.6_for_3.02.rar
Goog luck
Posted Apr 25, 2011 · 21:36 UTC#21
Thanks. Working on this. Using a 16Gb SD card from MicroCenter. The card seems to work fine. I have 4 SD cards, so the difficult part is keeping them all straight!, especially with changing contents!
Okay. Did the backup and the rename of sys.txt (I had two listings, same size and name, one minute apart in time. The first did not work but the second seemed to.
On step 3 (Reset + PWR) I t never shows the blue service screen, initially, ust black. (The boot seems okay, with the button lights coming on, until the shutdown. I never get to the key sequence or any further.) After 3-4 tries, I held it while trying the key sequence... finally, the blue screen after entering the key sequence again. Emphasize this step's ENTER is using DOWN on the joystick, NOT pressing it in, like a normal enter.
Copying files, now. Seems many of the maps are from 08 and 09.
Cool. Thanks sooo much! Seems to work, as I wait for the GPS to update location. Then, on to Diaftia's!
Yaay.. Yaaay. Yaaay. I'd pretty much wiped out using this 2nd unit, but now I am near where I wanted to go after starting some weeks ago with frustration at the small amount of info on the F500BT.
I encourage newer guys to just keep plugging and reading (takes a fair amount of time) and playing with the unit, getting familiar with the stylus and how CE works, etc. You can get there if I did!
Edited Apr 25, 2011 by whalepirot
Posted Feb 27, 2012 · 15:32 UTC#22
I have an aviic-f500 bt
I followed all the steps correctly. I ran the install and the check worked. I am told to restart the device. I can not shut it off as per usual. I hold the power button for 5sec shuts off. To restart i do the same thing. The device goes to the normal initial screen then it flashes whit e and shuts off...is there something I am doing wrong?
Any help would greatly appreciated.
