04 Mountaineer Video question
By Big Ed · Jan 02, 2011in Problems/Troubleshooting💬 2 posts👁️ 1,248 views
Posted Jan 02, 2011 · 22:00 UTC#1
Hello all...
Installed an avic910 into an 04 mountaineer using a 70-5521 and 70-5520av plugs.It does have factory rear overhead video. We get the pop issue on the audiophile amp system. we know it needs a voltage kick down due to 5volt out of factory deck. The problem we have ran into is with the use of the proper harness for the rear factory video (70-5520av) the factory dvd/video comes on for like 5 seconds and then shuts off. Our assumption is that it needs voltage kick down too. We hooked up factory deck again and everything plays normal so it has to be something simple like voltage kickdown like the amp uses in this car. Please help with any suggestions or if someone can point me in the right direction, etc etc.
Big Ed
Advacned Audio/Video
Rogers, Ar
Posted Jan 03, 2011 · 15:33 UTC#2
as far as the video problem, sorry i got nothing for ya, but for the factory sub pop, you need to place a resistor inline with the amp turn on wire (1450 ohms for the older systems and closer to 2700ohms for the newer systems)
