New iPod Cable, works perfect, but cant adjust sound?
By Brian1992 · Jan 03, 2011in Problems/Troubleshooting💬 11 posts👁️ 1,147 views
Posted Jan 03, 2011 · 20:26 UTC#1
Finally recieved my Pioneer iPod Cable, for my F700BT, video works great (Did the bypass before I even installed the unit), music works, everythings fast and smooth, but the volume is like at a set level....I can turn it from 0-60 or whatever it goes up to and I get no difference, and its only coming from the front door speakers, not my subs, nor rear speakers....
It seems almost like its in a dual-zone mode or something...
Posted Jan 04, 2011 · 04:46 UTC#2
Anybody?
Posted Jan 07, 2011 · 15:30 UTC#3
well there is no dual mode support for the F series, so if your main volume control os not changing the level of the sound, then it sounds like you may have a problem with the AVIC internal mixer.
Posted Jan 07, 2011 · 15:32 UTC#4
are you sure that you plugged the ipod cable's RCA's into the corect set of inputs? i would definitely check to make sure.
Edited Jan 07, 2011 by 1loudls
Posted Jan 07, 2011 · 15:59 UTC#5
Hm, would the RCAs be labeled? I plugged them into a set that was unlabeled.
Posted Jan 07, 2011 · 16:21 UTC#6
yes they are all labeled (or at least should be) you probably pluged the sudio in to the front audio outputs, and this is why that you only have sound in the front speakers and why you cant change the volume output
Posted Jan 07, 2011 · 16:22 UTC#7
they should be labeled "AV1"
Posted Jan 07, 2011 · 17:10 UTC#8
Well I hope it's that simple, I'll feel retarted as hell but I'll be happy
(Specially since im a techie kinda guy)
Thanks man I'll try it when I get home in a couple of hours.
Posted Jan 07, 2011 · 18:26 UTC#9
cool let me know if that the deal. if so dont feel bad, there should have been a label on that set.
Posted Jan 07, 2011 · 20:23 UTC#10
Awesome man, didnt even go inside when I got home I just ripped my bezel out (Not literally lol), and sure enough, I had the audio cables plugged in the Front Outputs, but the inputs didnt have any label on them, plus I had them zip tied away so I couldnt see them.
Thanks a million man! Now I cant wait to fab up a custom dock in my dash instead of having the cables in the glovebox :D
Posted Jan 07, 2011 · 20:39 UTC#11
sweet bro, glad it was super simple for ya.
