Factory Steering controls
By mboyer · Jan 04, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,241 views
Posted Jan 04, 2007 · 03:38 UTC#1
We have a 2001 Nissan Pathfinder LE w/Bose, Has anyone found a way to use the factory steering wheel controls???
Second, anyone having the problem in radio mode that the music is a different sound level then the commercials? My wife is contantly having to adjust the volume...any suggestions or ideas on a fix???
Matt
Posted Jan 04, 2007 · 03:57 UTC#2
I may be wrong but the swi-ps should work. check with pac on that.
no clue on the volume change amongst the same source during commercials
Posted Jan 04, 2007 · 04:03 UTC#3
Just verifed that PAC SWI-PS will work on Crutchfield's site by changing vehicle to 01 Pathfinder w/BOSE
http://www.crutchfield.com/S-aCjR5yMM9u ... i=127SWIPS
Check out the feedback section of the product. Someone already installed one on an 01 Pathfinder
Written by Ed, Encino, CA on August 21, 2006
I got this unit so that I could keep using the built-in steering wheel radio controls on my '01 Nissan Pathfinder. Installation can be a bit tricky. In my case I had to solder included resistors since each button on the control was wired separately but the adapter uses only one wire as input (white for my car). Important not to use resistors over 2k ohm for this vehicle!!! Manual didn't mention this and the first time I had some buttons not respond to programming until I replaced the resistors (all included). Other than that works exactly as expected. Very nice to be able to use the same controls!
I have the SWI-PS and it works great! Good luck!
Posted Jan 05, 2007 · 01:00 UTC#4
Thanks so much, that really helps!
