Streaming Video from iPhone 3GS
By schellski · Jan 04, 2011in Problems/Troubleshooting💬 9 posts👁️ 2,390 views
Posted Jan 04, 2011 · 23:55 UTC#1
I have an X920BT, terrific unit! It does everything as advertised and works exceptionally well with my iPhone.
I imagine my problem is a user error, so I hope I don't get lit up too bad.
My 3GS has no trouble showing video on the X920 when it is run through the direct connect. I simply hit the video tab on the 920 and select which show from my iPhone that I want to watch.
However, if I am watching streaming video (for example a game from my NHL Live app) the video does not show on the 920. I can hear it fine but I can't see it. I imagine that its because it runs through the iPhone media player (Quicktime, i think) and there is no way for me to access sit directly from the 920 controls.
Has anybody encountered this? I have checked the settings and the iPod settings on the phone, but can't find an answer.
In searching the forums, it looks like others have had no problem viewing the Youtube app and it uses the same media player so I must assume that I am missing something.
Anyone?
Posted Jan 05, 2011 · 00:06 UTC#2
Two methods:
1. Launch a video from the AVIC, then open whatever app you want on the iPhone.
or
2. Switch the AVIC from Navi control to iPod control, then open the app.
Demonstrated here:
Edited Jan 05, 2011 by JasonH
Posted Jan 05, 2011 · 01:31 UTC#3
That wont work unless the video app supports the Apple TV OUT extension and with the exception of Apple apps and the Netflix app there are no video apps that I am aware of that support it. However, if you jailbreak your phone you can make it work with any video app.
Posted Jan 05, 2011 · 03:41 UTC#4
Correct, I was assuming his app uses the built in quicktime player.
Posted Jan 13, 2011 · 19:11 UTC#5
I have the same problem with my 3GS and X920 as the OP - no Netflix video when I open the app exactly as shown in the video posted above. Can hear the audio, but no video on the 920. Is the phone used to demonstrate watching a Netflix video a 4G, or perhaps jailbroken?
Posted Jan 14, 2011 · 01:30 UTC#6
Is the phone used to demonstrate watching a Netflix video a 4G.
Its an i4 and that may be required to get TV OUT unless you are jailbroken.
Posted Jan 14, 2011 · 01:35 UTC#7
Confirmed! i4, iTouch 4G, and iPad only for Netflix video out. A jailbreak will solve that problem however if you have an older iDevice.
Edited Jan 14, 2011 by VBLUE42
Posted Jan 18, 2011 · 17:12 UTC#8
I am using the NHL Live app. I am pretty sure it does use the QT player, so I think the original posted solution may work. Although after reading bashed1's post maybe not!
I have had my car parked for the last few weeks, so I haven't had the chance to try it yet. I should get a chance tonite, though.
I'll post my findings. Thanks so much for all the replies and info.
schellski
Edited Jan 18, 2011 by schellski
Posted Jan 26, 2011 · 02:42 UTC#9
schellski
As mentioned, the YouTube and iPod apps in the 3Gs work, but not my NHL live app. It would seem that it doesn't support the TV out as was previously mentioned in the thread.
SO - I have never been that interested in jailbreaking my phone simply because there were always issues that arose when I used to crack my WindowsMobile phones. My next questions are:
Is there an app I could get that would alleviate the problem without jailbreaking?
And if not, does jailbreaking cause any problems/issue with the 3GS? I guess I can answer the 2nd question with a search, but how about the first?
Nevermind! I found the answer to both questions when searching...
Thanks for the helpful forum
Edited Jan 26, 2011 by schellski
