F700BT backup files
By Attila · Jan 06, 2011in Hacks/Mods💬 25 posts👁️ 17,605 views
Posted Jan 06, 2011 · 13:49 UTC#1
Hey guys,i own an f700bt that i bought in USA about a year ago.I live in Europe an thought i might get some use of a Europe map instead of the USA-Canada ones that came with the unit.I found AVIC411 on Google and i was trying to put together all the pieces of information that i found here on how to do the process.Of course,since none of you had a bright idea of opening a topic with a complete installation with all the steps that i would have to go through,i messed up thing in the unit.The info shown on this forum is only bits and pieces of a whole picture and so someone that has no idea on how to do it from top to bottom,has the option to guess certain steps.(which in my case,failed)So I am asking any of you.....DOES ANYBODY HAVE A COMPLETE INSTALLATION GUIDE FROM A TO Z WITH LINKS TO DOWNLOAD THE NECESSARY FILES!?
AND DOES ANYONE HAVE A COMPLETE BACKUP OF THE AVIC F700BT(US VERSION)FILES!?
Much appreciation to whoever will be capable of enriching this thread with info,the way i asked...and I'm sure most of the people on this forum are looking for this particular type of step-by-step information(even explaining technical words)
Thank you
Posted Feb 13, 2011 · 17:26 UTC#2
I've managed to get the USA F700 Backup files so if anybody interested,just let me know....
Posted Feb 15, 2011 · 17:10 UTC#3
I would be intrested in a copy of F700 files. Im working on one now that has been screwed up before i got it.
Thanks in advance.
Posted Feb 27, 2011 · 00:28 UTC#4
i would also like a copy of the files. if you could pm me the files or email them to me that would be great. [email protected]
Posted Feb 27, 2011 · 00:42 UTC#5
i would also like a copy of the files. if you could pm me the files or email them to me that would be great [email protected]
Posted Mar 02, 2011 · 12:22 UTC#6
Sorry for the late answer,i've been busy doing other things and only today i noticed your request.please download the files from the links below.On the root of a blank card(at least 2 gb),copy the "Testmode" file and the "F700" file,enter windows CE of your unit,open total commander and erase the whole content of My Flash Disk folder(but keep the folder),copy the content of the F700 folder from your sd card into My Flash Disk.After the process is done(about 10 minutes so you should keep your engine running)just switch your car off,take the sd card out and then switch the car back on.There you go.You should have a brand new F700.If for some reason you can't do it,let me know and i'll try to answer your questions.Anyway,let me know how it worked for you.
http://www.2shared.com/uploadComplete.jsp?sId=60DILhabp7cAXorb
http://www.2shared.com/uploadComplete.jsp?sId=Y86zW2Irzlj7XLVr
Posted Mar 03, 2011 · 03:33 UTC#7
link brings me to upload page. there is no file to download on the pages
Posted Mar 19, 2011 · 16:41 UTC#9
you're right dude...sorry about that...try the following and obey the steps above.
http://www.2shared.com/qs/1/f700
http://www.2shared.com/qs/1/testmode
I tried using your back up and its just boot looping. Wondering what version is that backup. Can anyone confirm if these files work?
Posted Mar 31, 2011 · 12:09 UTC#10
It's 2.0 and i was prettu clear about the instructions.I can't help you more,i'm sorr.
Posted Apr 21, 2011 · 21:24 UTC#11
I tried, but now my F700 doesn't want to boot up fully. It just stays on the Pioneer screen.
Posted Apr 25, 2011 · 19:32 UTC#12
I am sorry to hear you have encountered problems.Are you sure you have a USA unit?Did you follow my instructions entirely?
Posted Apr 25, 2011 · 19:35 UTC#13
Rebooting huh!? Try deleting the 4 GpsParaX.bin files from the root of myflashdeisk (safe, system re creates them)
Posted Jul 14, 2011 · 14:08 UTC#14
This sounds like solid info, and sounds like what I need to do.
Problem is, my unit is showing a blank screen at this time and won't boot. How do I "enter windows CE of your unit, open total commander....."
Sorry....new, frustrated, but motivated to fix my junk!! Thanks!
Posted Mar 06, 2012 · 22:10 UTC#15
There is no flash disk file only a flash disk drive. What do I delete and where do I put the new back up files
Posted Mar 07, 2012 · 18:24 UTC#16
So I follow the steps provided and when it starts to transfer all of the files from that folder to the new my flash disk, i get a lot of error messages saying can't load file or cannot access file. Is there anything else I can do to fix all of this? I know the unit itself works because i'm able to get to total commander and play around with files and move them wherever I want, all of this is just a software issue.
please help!
Posted Feb 15, 2013 · 10:35 UTC#17
Hello guys,
I also own a f700 bt and wont work since two weeks..
Can any one help my with the complete files for my flash disk..
I live in Europe and I own a European system..
Many thanks,
Posted Jul 03, 2013 · 11:23 UTC#18
Hi, i need help with my f700. I need backup file for f700. Mine already corrupted
Posted Oct 11, 2015 · 22:42 UTC#19
I'm intrested in a copy of F700 files. Im working on one now that has been screwed up before i got it. if you can email it to me at
[email protected]
Thanks in advance.
Posted Aug 03, 2018 · 21:18 UTC#20
I am also in need of the F700 files.  My car has been in the shop for the last 6 weeks getting repainted.  When I picked it up yesterday I had several new issues.  ABS Light is on, Trunk Open light is on, right rear turn signal went out after driving out fo the shop, and my Avic-F700BT will boot then turn off.  It's a good thing the paint job is excellent or I would have lost my mind!The turn signal is fixed, seems there was a crimped wire.  My mechanic is ordering me a new trunk lid switch and will look at the ABS light issue when the other part comes in.  There was NOTHING wrong with the car when I dropped it off 6 weeks ago.
I managed to get the TestMode files and I can get into Windows CE fine, but that's about it.  Soft reset was no good and I tried deleting to 4 GPS files that people have mentioned.  At one point, I tried holding the Menu, Map, & Eject Button and got the hit Reset one more time message.  I push the soft reset button and it booted to the GPS Warning while Driving screen with the OK button.  Pushed the OK and nothing, turned the car off and back on and it goes back to booting, then Off.  I really don't want to buy a new head unit, but if I can't get the files I need I guess I will have to.  All of the links on all of the message boards for the F700 files do not work, UGH!
Any help getting the files would be greatly appreciated.
Posted Oct 05, 2021 · 10:53 UTC#21
I need these backup files please email me [email protected]
Posted Oct 21, 2021 · 11:54 UTC#22
Atilla any chance you still have a working backup file
Posted Mar 02, 2022 · 15:38 UTC#23
Do what I posted here:
It worked like a charm for my F700BT.
Sorry so long, but I don't frequent here as much as I used to.
Posted Jun 01, 2022 · 21:08 UTC#24
I would love these if you still have them!
Posted Nov 17, 2024 · 02:04 UTC#25
