Bluetooth Password
By B3-ST · Jan 06, 2011in Problems/Troubleshooting💬 4 posts👁️ 952 views
Posted Jan 06, 2011 · 17:40 UTC#1
Have a new phone, a Samsung Incognito and want to pair with by Z120BT.
My problem? How do I specify a bluetooth password on the Pioneer with the alphabet and NOT numbers? My Samsung phone doesn't seem to allow me to type in a 'number only' sequence when pairing.
Thanks in advance,
B3
Posted Jan 06, 2011 · 17:57 UTC#2
The pioneer only support numbers for BT PIN code. And i have never seen a phone that didn't support numbers for its PIN code. You are likely running into some other compatibility issue with that phone.
Edited Jan 06, 2011 by VBLUE42
Posted Jan 06, 2011 · 18:40 UTC#3
Hi Vblue42:
My phone naturally types numbers for calling, web browsing etc. The problem is to select a number on the interior keypad you must hold the 'function' key while pressing an alpha/numeric key and to get to the numbers which can take anywhere from 3 to 8 clicks to place the number on the screen. I'm sure there's a way to do this, should probably call my phone vendor.
Thanks, B3
Posted Jan 06, 2011 · 20:23 UTC#4
Really, in the day of phone vendors trying to compete with the iPhone I find it hard to believe that it would be so difficult to enter numbers on a keypad. Hopefully its something easy. Good luck with that.
