F90bt starts up, no pioneer logo screen, then blank screen
By BulletHead · Jan 08, 2011in Problems/Troubleshooting💬 14 posts👁️ 6,445 views
Posted Jan 08, 2011 · 19:01 UTC#1
i have a F90bt and it was running fine until i jumped a friend's car which had a dead battery. now it starts up, all the buttons light up and then the lights go out. nothing on the screen every shows up, it stays blank. the unit is ON but screen is blank and none of the buttons do anything.
any ideas?
Posted Jan 15, 2011 · 00:50 UTC#2
I have the same problem :( If I find anything, I'll post here too.
Posted Feb 07, 2011 · 19:14 UTC#3
can anyone help??
Posted Feb 09, 2011 · 14:19 UTC#4
i cant get into test mode, i dont see the pioneer logo screen on startup, its just a blank screen, please help.
ive update from 2.0 to 3.0 and 3.01 before.
Posted Oct 20, 2011 · 23:17 UTC#5
Anyone? I have the same problem too...
Posted Oct 30, 2011 · 18:56 UTC#6
Same problem here, no pioneer logo, black screen, powers off after 15-20 seconds. I cannot load testmode, however, I can get into the service menu but I cannot do the following:
1. perform a wince upgrade, it gets to reading 100% and just sits there
2. formatMBR, just keeps putting me back to the top of the menu list
I scoured through the forums and most people indicate bad nand memory. At this point it's either ship it back to pioneer or find someone who can service avic units, or unless someone else has a better suggestion.
-sai
Edited Oct 30, 2011 by saitou187
Posted Nov 05, 2011 · 21:30 UTC#7
Right there with you guys. Have tried the Wince upgrade and reloaded v2.0006 and it won't read the testmode files. Just sits there. I can get to the top level menu but the only active thing is the system settings and only a few things there. No AV, map, etc.
Hoping someone has an idea.
Posted Nov 06, 2011 · 21:30 UTC#8
I have the same issue with my f900bt. Just happened all of a sudden. Unit is stock with 2.0 update only. Worked fine when I shut the car off on Friday and then the car sat all day Saturday. Started it up this morning and noticed the radio did not come on. The buttons light up for 20 seconds and then go out. I can hear the fan still running in the background. When I try to enter the service mode by holding down Reset, Menu, Map, and Eject, the lights all go out. When I release Reset, the lights start flashing but still nothing happens. The screen stays completely black. Any suggestions anyone has sure would be helpful.
Thanks.
Edited Nov 06, 2011 by billc1015
Posted Nov 10, 2011 · 21:40 UTC#9
Hey Bill, elsewhere on this site are instructions on how to go through the process of doing a WINCE update and getting the system into TestMode where you can reset the box. It requires downloading some files onto a couple of SD cards. I've already tried those steps and can't get it into testmode so I'm stuck. Hopefully your unit will respond just like the others that got it fixed.
Posted Nov 11, 2011 · 19:01 UTC#10
I already tried that but like you, I can't get into testmode. For now I am using a 700bt that my father had in a car that he doesn't drive anymore. I found a merchant on ebay that repairs these units for about $120. I may decide to go that route if I can get some extra cash. For anyone else who is interested, the website is www.turbotunes.com.
Posted Nov 15, 2011 · 21:57 UTC#11
I called Pioneer tech support and the totally unenthusiastic guy on the phone said, "sounds like you need to send it to us". Alrighty then, guess that's my only option save your turbotunes.com. I'll check them out too, just in case.
So now I'm trying to figure out how to get my unit out. The double din bezel on my Altima doesn't want to pop out so I'm afraid of just breaking it. But I can't see any way that it's connected to either the unit or the dash. The guys at CarToys said it should just pull out but that isn't working. Anyone have any ideas?
Posted Sep 24, 2012 · 02:06 UTC#12
Anyone have a fix for this issue?
Posted Sep 24, 2012 · 02:29 UTC#13
Are you having symptoms do to the same situations, ie jump start?
Posted Oct 24, 2015 · 01:07 UTC#14
Have the exact same problem after jumpstarting a car with the exact symptoms.   Possible something got fried?
Any thoughts, suggestions, fixes?!  Pleeeease.
