Avic Application
By danimal86 · Jan 11, 2011in Pioneer AVH Series💬 12 posts👁️ 4,977 views
Posted Jan 11, 2011 · 06:56 UTC#1
I just plugged my avic-u220 into my computer for the first time, and i loaded the clock and picture loader. Are there any other application to load on the avic-u220?
Also, how long did you wait till you got the email from pioneer to get the poi loader info? They also charged me $5 even though they said its free?
Posted Jan 12, 2011 · 05:20 UTC#2
Anyone know any applications to load?
Posted Jan 13, 2011 · 06:41 UTC#3
Hi, i just got the AVIC-U220 and i cant find any applications. How did you get the clock and picture viewer?
Posted Jan 14, 2011 · 05:45 UTC#4
Download the Avic Feeds application (should be able to find it using google), install it on your computer, put a SD card in the u220, plug it into your computer using usb cable, and install it to the gps unit.
the given applications are kinda useless, its a clock (ripples when you touch the screen) and a picture viewer. i want something cooler!
Posted Jan 14, 2011 · 16:44 UTC#5
Thanks for the reply, i did all that with no luck, ill keep trying. The apps dont sound very interesting from what you said, other apps would be cool. Thanks
Posted Jan 14, 2011 · 20:55 UTC#6
what do you mean by "no luck"? what did it do? It worked first time for me. Were you able to get it loaded on the sd card? All you have to do then is fire up your car, go to the Nav menu, click applications and it'll ask if you want to load the clock or pic viewer.
Posted Jan 14, 2011 · 21:35 UTC#7
when i connected the u220 to avic feeds, i didnt see option to add apps. I did see the SD option at bottom and i clicked it, it said it saved. I went to my car, and in the applications folder still no content. So i have no idea what im doing wrong.
Posted Jan 15, 2011 · 04:35 UTC#8
are you able to upload anything to the SD card? It will only accept a Fat32 format, make sure its not NTSF.
Plug U220 into computer
Open Avic Feeds
Click on Applications, window should pop up asking to select memory device, click on sd card.
(see attached image), it should look like this (except the right side should show your sd card data)
Click on the check box's on the left of the applications, and click on the sd card. it should transfer over.
If this doesn't work, you might want to call pioneer...
good luck
Ohh yeah, you're not using a mac are you? I dont think avic feeds is compatible.
make sure you're connected to the internet, i think the applications are located on a server.
Edited Jan 15, 2011 by danimal86
Posted Jan 15, 2011 · 19:54 UTC#9
when i select hardware for avic feeds, i do not have the option of selecting the U220, maybe thats my problem. I know there is an updated version but when i click to update it takes me to a website that doesnt exist. I am using windows 7, maybe it doesnt work with win 7.
Edited Jan 15, 2011 by clipman
Posted Jan 15, 2011 · 20:28 UTC#10
Thanks for all your help, i had an older version, i was finally able to update version and i see the applications folder, thanks again.
Posted Jan 17, 2011 · 22:20 UTC#11
glad you got it to work...let me know if you ever find any other apps to load on the U220
Posted Jan 21, 2011 · 00:24 UTC#12
will do!
