920BT GOING CRAZY
By polanco · Jan 12, 2011in Problems/Troubleshooting💬 7 posts👁️ 1,526 views
Posted Jan 12, 2011 · 02:17 UTC#1
I GOT A AVIC-X920BT INSTALLED IN MY 05 CHEVY TRAILBLAZER
OK HERE'S THE PROBLEM THE AV SOURCES AS WELL AS THE RADIO STATIONS SOMETIMES GO HAY WIRE N START CHANGING ON ITS OWN .
I TOOK IT BACK TO THE SHOP AND THEY CAN'T FIGURE OUT THE PROBLEM EITHER I USED A PAC AUDIO SWI-PS FOR THE STEERING WHEEL CONTROLS
AND OS-2CBOSE FOR THE ONSTAR N BOSE SYSTEM. HAS ANYONE HAD THIS PROBLEM WITH THERE UNIT ?
Posted Jan 12, 2011 · 02:23 UTC#2
HAVE THE PAC MODULES LOOKED AT AND WHILE YOUR AT IT, HAVE THAT CAPS LOCK KEY CHECKED. ONCE THE LATTER IS FIXED FEEL FREE TO POST AGAIN.
Posted Jan 12, 2011 · 02:44 UTC#3
they looked at the modules n said that they are plugged in correctly. so i dunno what it is
Posted Jan 12, 2011 · 05:33 UTC#4
Well either they didn't look very well or you have a defective unit. Have it replaced and see what happens. Nice going on the caps lock BTW.
Posted Jan 12, 2011 · 22:52 UTC#5
you think i have a defective Head unit?
Posted Jan 13, 2011 · 00:20 UTC#6
Possibly but faulty PAC modules could also be the problem. Follow my advice and see what happens.
Posted Jan 13, 2011 · 18:57 UTC#7
i would lean on more of a defective PAC module over a bad headunit, if the wires where not soldered, that could be causing an issue with reading the corect resistance of the factory controls, GM's are pretty consistant with there steering wheel controls working with out a problem.
