Navigation is backwards
By phoenixreborn · Jan 16, 2011in Problems/Troubleshooting💬 4 posts👁️ 992 views
Posted Jan 16, 2011 · 23:04 UTC#1
I just installed a Z110BT in my 04 Avalanche, everything is good except that the navigation is showing that my truck is facing the other direction.
The arrow is spot on as far as location goes, but its just reversed. Anyone have this problem before? Any help is appreciated.
Thanks.
Posted Jan 17, 2011 · 01:40 UTC#2
Thanks.
I guess you just need to drive backwards :lol:
Sorry, couldn't resist....
Do you have the Violet/White (REVERSE GEAR SIGNAL INPUT) wire connected? From the installation manual, " Unless connected, the sensor may not detect your vehicle traveling forward/backward properly". Although mine is not connected, I am not having this problem.
If yours is connected, it is possible you don't have it connected to the right circuit (always on or high when going forward).
Next check the polarity. Go to Home/Navi Settings/Connection Status. Make sure that when the gear is shifted into "Forward", the 'Back Signal" value is "Low".
To correct it, I think you go to Home/System Settings/System Settings/Back Camera/Camera and change the polarity.
It must have to do with the unit incorrectly thinking you are going in reverse. These are the things that come to mind.
Edited Jan 17, 2011 by RonS
Posted Jan 18, 2011 · 17:13 UTC#3
Thanks.
I have an 04 Avalanche. I implemeted the GMOS04 harness and everything works fine except that I had to run a seperate wire to tap into the lighting system for the dimmer to work properly since the GMOS04 didn't deliver any voltage change to either the Dimmer or Immumination wires.
Posted Jan 28, 2011 · 06:57 UTC#4
Did you have the AViC installed in any vehicle previously? I had the same problem after moving it from one vehicle to another. A reset fixed it.
