Screen off button. Can we copy this button to another location?
By dxorcist · Jan 17, 2011in Hacks/Mods💬 4 posts👁️ 1,603 views
Posted Jan 17, 2011 · 16:09 UTC#1
I think it is nice to be able to switch off the screen (especially at night) or when you just listen to the radio. I am able to switch the screen off by going into System Settings > Screen off, however, is there a way we can copy this button anywhere else? For example, the main menu screen?
Many thanks in advance
Posted Jan 27, 2011 · 02:48 UTC#2
No, it is not possible. We cannot change the script in the Main/AV part of the unit, only the navigation part. There is several ways of doing this with a button in the Nav section though.
Posted Feb 04, 2011 · 07:35 UTC#3
You could just make a screen off ui file (just a black background) and put a button someplace on the nav screen. You want what I have created in my mods but I added the date and clock (as well as weather for msn subscribers). Just make the black background a button back to st_navigatemap.
Posted Feb 12, 2011 · 04:02 UTC#4
Yeah you can do that but this is not a true OFF, because you are still going to see the backlight from the LCD.
I found the solution by using an executable file called ScreenOff.exe, and I posted it here: My thread!
Use it at will! I will make it available on my upcoming update to my mod. :rolleyes:
Edited Feb 12, 2011 by Chuck88
