is there any mods or ways to hack dvd regions?
By pho1982 · May 21, 2006in Hacks/Mods💬 9 posts👁️ 2,306 views
Posted May 21, 2006 · 18:47 UTC#1
i have a lot of dvds which are not regional coded 1.
is there any way to hack it and make it free region player?
Posted May 21, 2006 · 20:40 UTC#2
It's probably easier to just make region free dvd's. I did and it plays mine. Most any program like dvd decrypter or dvd fab decrypter and then dvd shrink will remove all region encoding, then it will play it.
Posted May 21, 2006 · 23:05 UTC#3
u meant make dvd discs to region free?
so then what is decrypter? and the term "shrink"?
i'll appreciate your help!
Posted May 22, 2006 · 00:25 UTC#4
You stick the original DVD into your PC, with a dvd burner and "decrypt it" with a program DVD decrypter. Gets rid of copy protection, macrovision and I think the region too.
Then the problem is some dvd's are up to 9 gigs (dual layer dvd's) and most people can only burn single layer 4.5 gig dvds. I get single layer DVD's for $0.35 or so for Ritek (best disks, I buy mine from www.shop4tech.com). So you need DVD shrink to shrink a 9 gig dvd to fit on a 4.5 gig dvd. I ususally take out all the forign languages and drop the quality of the special features, and the main movie usually is decreased in quality to about 60%-70% wich you won't notice.
This guy has a tutorial
http://www.mrbass.org/dvdshrink/
Or what is even better, for the car, I take my DVD's and decrypt them and then use dvd shrink to pull out only the movie, so when i put them in my car, I don't have to go through all sorts of previews or menus or anything. It just plays the movie.
But either decrypter or dvd shrink will remove the region encoding from your new disk, so the one you will burn will be region free and should play in any disk.
I have done this for some friends who get disks from other parts of the world, I run them through this process and give them their original disk and a copy which will now play in any american dvd player.
Posted May 22, 2006 · 17:42 UTC#5
DVD-9's are also dropping in price, I just picked up a spindle. I'm curious to see if the Z1 will read the second layer...I'll report back. On a side note if you do have a dvd burner I'd recommend Roxio's latest creator software...the audio-dvd function works great.
Posted May 22, 2006 · 23:33 UTC#6
They should be able to read it. I haven't tried DL DVD-Video but I did update my N2 to the CNDV-60MT software using a Memorex DL DVD+R. I'm thinking, if the N2 can do it...the Z1 can probably do it too.
Posted May 26, 2006 · 02:58 UTC#7
I was able to play ntfs and pal discs in my z1!!!
Good stuff
Posted May 26, 2006 · 05:26 UTC#8
Good stuff
NTSC. NTFS is a file system in Windows NT, 2000, XP, 2003, and Vista.
heh.
Posted May 26, 2006 · 23:34 UTC#9
sorry ,ntsc tes that is what i ment. I have not tried other regions though
