Hey All, I recently picked up a AVH-P4000DVD Head deck for a sweet price of $160.00. I've done a considerable amount of reading on this and the others in this family of decks. I've Installed it in my 2006 F-550 6.0 Power Stroke XLT Super Duty utilizing Tips and Suggestions provided by members of various Forums. I've done the Parking Break Relay Override and all is good with playing DvD's on the go and all other functions of the unit work flawlessly except for the back up camera (which is the whole purpose of doing this head deck swap) which I for the life of me cannot seem to get up and running. I'm not a electronics whiz by any stretch of the imagination BUT do possess a fairly good working knowledge of and desire to learns myself above the "I Know Just Enough To Be Dangerous" Level of Know's.
My issue is after hooking up the rear view cam everything seems to be working but the screen of the Head Deck is black but does have what appears to be interference lines Diagonally across the screen but regardless of the settings I try nor switching around ALL the wires for the cam, All One of them unless you count the RCA Video Lead which would bring the Grand total of wires to a whopping TWO.
Here is the connections I have at the moment, maybe one of the Gurus here on the site could enlighten me as to WHAT I Am so Obviously Over Looking or just plain and simply have screwed up.
I have connected the Violet/White Wire (the one With the factory inline Fuse Resistor) that comes out of the head units wiring harness connected to the rear back up light wire that energizes to 12vdc when the truck is put into reverse. The RCA Lead is Run from the BROWN RCA Connector of the head deck to the Yellow RCA Connector of the Rear View Camera. I've read and re read the User/Install Manual Left to Right Right to Left Upside Down Right Side Up (Well you get the picture) but feel although a valiant effort has been put forth that I am missing something very trivial that is keeping the cam from functioning correctly. The one concern I have is the manual has no reference to or even mentions for that matter the purple/gray wire that is located in the area just below the RCA outputs on the rear of the Deck. Initially I thought this wire was the wire they refer to as Violet/White but when I took note that this wire had no resistor/fuse inline I dismissed that idea, perhaps wrongly but that is why I is here ladies.......for help!! Doe's the Violet/Gray wire play a role in the reverse cam? If so where does it get connected? Any Settings I may have missed during setup?
Any Help is Greatly appreciated by me and will surly put a smile on the Grand daughter's face when I get the Back up Cam bugs worked out and she can finally watch one of her videos while out and about with her papa in her "Papa's Big White Work Truck".
thanks guys
Les
