is it okay to use the radio antenna signal wire instead of the remote control wire to send signal to the amp? if yes should i put the radio antenna to power mode? tnx by d way i have avic d3
radio signal wire/remote control signal wire
Should be ok as long as it's in power mode.
tnx just worried that i may fry my amp. do they have the same voltage output?
Yeah they're both 12v.
tnx. jusg dont want to remove the unit again and swithc the wires
I did connect the radio antenna wire to the remote signal of my Infinity Basslink. The Basslink is always on even if my D3 is off. So whenever the car is on my basslink is also on. Is this normal with the D3. I have the same thing on my other car but my HU is a pioneer m80bt and the basslink only turns on when the HU is on. Any insights will help...tnx...
yes all AVIC's keep their amp wires and ant wires (if set to power)powered up any time the unit has power because they dont fully shut off when you turn it off, just the audio side shuts off. (that way, if you have a route planed it can still give directions with the radio being off)
