Radio Antenna Wire on Power Mode
By aaronmp2315 · Jan 28, 2011in General💬 4 posts👁️ 1,272 views
Posted Jan 28, 2011 · 07:55 UTC#1
Can i use the radio antenna wire to power up a headrest monitor if i put it into a power mode?
Posted Jan 28, 2011 · 08:35 UTC#2
I wouldn't, it's not really designed for that much load.
Posted Jan 28, 2011 · 18:05 UTC#3
you can use the Ant wire to power up a relay that would provide power to the headrest monitors.
Edited Jan 28, 2011 by rgarjr
Posted Feb 04, 2011 · 15:48 UTC#4
yes you can use a relay to be able to use the low current output of the ant wire to provide enough current to power the monitors, but if your going to have it into power mode, then why not just hook them up to an ACC power source?
