D3 from a VW GTI to an FJ Cruiser Help
By Boonedock82 · Feb 01, 2011in Problems/Troubleshooting💬 4 posts👁️ 954 views
Posted Feb 01, 2011 · 19:48 UTC#1
Hello everyone,
Well as the title says. Moving a D3 install from a VW GTI to an FJ Cruiser. Looking at the wiring I have some questions before I start diving in. Of note I also had a sirius unit and a couple swi controller for the GTI (Sirius is comming over controllers are no longer needed and I have already removed them from the harness)
First things first.
Bypass was previously done with the mute wire grounded and I can't remember what the green wire is???? (had it installed by a shop, I am ok with stereo wiring but wasn't ready to take on this project from scratch on a VW)
Ok first question. They had the ACC wire running off to some place behind the dash that I couldn't find and I a assume that it was a switched power supply. I just cut the connection and taped it off. In the FJ I am hoping that I can just connect it to the red wire in the harness. It looked like this was attempted by the installer then cut off. Should it not work just fine to have it wired up to the factory adapter?
In the next picture here you can see where the acc wire was originally connected. It also goes on to connect to the shrink wrapped what I assume is a circuit board. Anyone care to elaborate as to what that is?
Here is where I get really confused. That switcboard or what ever it is had 4 wires running into it the yellow and black routing back to the harness they are paired at the factory adaptor harness (2 yellows and 2 blacks comming out of the factory harness adaptor) and the purple w/ black stripe and the pink wire. Out going from the board are the orange / white wire and the red acc wire which is not connected to anything. Getting more confusing.
Here is where the power supply to the Sirius unit goes. Interesting thing is that the yellow wire is connected to the red wire going into the sirius unit? Is there any significance to this. Should it be changed to the yellow or just left as it is?
The more I look at this and the more I have to explain it the more that I feel like I am likely over my head still with this and should just pay someone to do it for me. Any suggestions would be great my skills to really range beyond matching wire to wire so this may be out of my league.
Long time lurker first time I needed to post!
Posted Feb 04, 2011 · 16:13 UTC#2
A ) to bypass the system (watch videos while driving) you need to move the mute wire (should have already been done) and ground the mute wire and the P-brake wire (light green wire)
B ) that device with the shrink wrap is a can bus adapter, most newer vehicles dont have a standard ACC wire comming off of the harness (the FJ will) that device reads the on and off commands from the can bus and converts to to a simple on/off ACC signal, this will not be used in the new install.
C ) if the sirius worked befor, dont change anything, one possibility is that the orignal plug is gone and the replacment has a different pinout.
Edited Feb 04, 2011 by 1loudls
Posted Feb 07, 2011 · 18:16 UTC#3
Awesome! Thank you soo much!!!!!!!
One more quick question that maybe you can answer for me. In the previous instal the VSS wire was left unconnected. The unit seemed to work just fine for me now for over 3 years. Should I be fine without installing it on the new rig?
Posted Feb 07, 2011 · 20:46 UTC#4
yes it will function just fine with out the VSS connected, the VSS just increases accuracy when there is trouble getting sat signal.
