Sorry but this is a repost from accidentally posting in the D series forum.
I took the f700bt apart to see if the pico fuse was blown because I was getting some noise. After putting it back together, the volume control no longer works but I can push the rotary button up and down and get response. So the rotary function no longer works.
I was wondering, is this likely a ribbon cable that has been damaged? If so, does anyone know which ribbon cable the rotary knob uses to communicate with the main board? Theres a few ribbon cables in there, one big one and a few smaller ones. I may try replacing the ribbon cbale to see if that fixes it.
Any help much appreciated.
