F90BT Clock
By avicpilot · Feb 02, 2011in Hacks/Mods💬 3 posts👁️ 2,187 views
Posted Feb 02, 2011 · 12:10 UTC#1
Any Hacks/Mods out there to make the clock bigger on the F90BT?
I know the general consensus is to make it go away altogether since most newer cars have a nice digital clock already installed. But I've recently installed the F90BT into a 2002 Tahoe LT, and the only clock was on the factory head-unit.
My first thought is simply replacing the Source Icon with a larger active clock... pushing the clock will still perform the source function.
Anyway... anyone have any ideas for making it a bit more noticeable?
Edited Feb 02, 2011 by avicpilot
Posted Feb 04, 2011 · 07:15 UTC#2
You can do one of two things:
1. Open up the zip file and edit the navigatemap_800_480.ui file. Find the line for the clock and make the fontsize= value larger.
2. Check out the completed mods section and see if one of the existing mods has what you need. In my mods for example it's a little larger. What I do have though is a custom "off screen" accessible via a quick menu that would allow you to bring up a screen with a really big clock and date. If you have an MSN sub it will also show the current weather.
Posted Sep 25, 2013 · 18:12 UTC#3
will this change both the clock in the nav and a av source?
