Avic-z110bt not working
By Jacksworld718 · Feb 03, 2011in Problems/Troubleshooting💬 6 posts👁️ 1,641 views
Posted Feb 03, 2011 · 20:31 UTC#1
I had this installed to my 02bmw x5 everything has been working fine til yesterday it revolted twice then today it shutoff and now I get the screen cut in half white dots and other half red dots fallowed by black and white thick lines running threw from left to right then blank screen with the buttons light if I press eject it opens without a hassle if I throw the car in reverse before it blacks out I get my backup camera working what is going on?? Amazon is willing to refund me my money although I had it for 8 months now I checked to see all my wires are plugged in nice and tight is the unit defective or is there a problem with the wires maybe the ground gave out please help
Posted Feb 03, 2011 · 20:32 UTC#2
Oh I upgraded the formats to the z120 I actually paid for the sd card they sent over but that was done a few months back
Posted Feb 03, 2011 · 21:07 UTC#3
Send it to amazon and get z130bt when it comes out.
Posted Feb 04, 2011 · 15:14 UTC#4
Do u think it's a bad unit or is it a wire problem like bad ground ?? I'm scared to put a new unit in and have it get burnt again??? Like I said it was all working fine
Posted Feb 04, 2011 · 22:27 UTC#5
First check all your connections carefully. If you have doubt take professional help. If unit is bad get your money back while you can.
Posted Feb 05, 2011 · 00:42 UTC#6
You might want to pull the HU and bench-test it. All you really need to connect are the red (+), yellow (+), and black (-) wires. If that works, it's your installation wiring. If not, its your HU.
You can do this yourself if you know how to remove it from the dash. Seeing it is a BMW, there is probably a trick to it. So your next option is to let your installer check it.
