Ipod alphabet scrolling messed up
By tallboy · Feb 05, 2011in Problems/Troubleshooting💬 2 posts👁️ 918 views
Posted Feb 05, 2011 · 17:47 UTC#1
So when I first hooked up the x920bt, the artist alphabet worked great. Now for some reason, whatever the 2nd letter in the artist name ("P" in A Perfect Circle, or "T" in A Tribe Called Quest) is the top of the alphabet. So instead of it being at "A" at startup, it's at "P" and then the rest of the alphabet isn't found (I can't select "M" because it says it isn't found). Anyone come across this problem?
Second question, is there a way to go from the now playing screen back to that artist's album browser? When I select the artist that is playing, it takes me to the top of the artist alphabet, not the previous screen that has all the album's under that name.
Posted Mar 29, 2011 · 05:59 UTC#2
Some time ago, i had similar problems with the tabs. It helped to restore and resync the ipod.
There is also a mp3-tag "sort artist" (or so), perhaps it's filled correctly and behave as it should?
