R Bluetooth modules good?
By mcguyver2010 · Feb 09, 2011in General💬 10 posts👁️ 2,159 views
Posted Feb 09, 2011 · 06:35 UTC#1
I was wondering how people felt about the Bluetooth modules for the z series avics. Are they a good option and do they work well? How many different ones are available for the z series and is one better than the other? Do they cause any problems (i.e. freezing up the unit or causing technical problems)? Finally, where is the best place to get a good deal on a Bluetooth module?
I also wanted to know if there was a way to get the steering wheel controls on a 2002 excursion to work with a z2.
Thanks.
Posted Feb 25, 2011 · 04:26 UTC#2
Thanks.
The blue tooth module for this unit works well there is only one unit and I suggest Ebay. You can buy an interface kit that you can program for the use of your sterring wheel controls but I had problems with it in my 07 F-150. I ended up using the Sir steering wheel remote which works great
Posted Feb 25, 2011 · 14:36 UTC#3
Pioneer's website shows that the BT box ND-BT1 is used with the Z2. But when I look for it alot of places online show it to be discontinued part.
I have looked at eBay, and found a couple.
Will the CD-BTB200 work instead of the ND-BT1?
Posted Feb 25, 2011 · 21:55 UTC#4
No it was for the earlier D3 units if I remember correctly. Try to get the ND-BT1. Yes they are becoming old school which is which I suggested Ebay.
Posted Feb 27, 2011 · 14:25 UTC#5
Goldcylon, what kind of problems did you have with the steering wheel control kit on your F 150? I'm concerned I will have the same problem with my ford.
Thank you, I appreciate the input. I'll hunt down a BT-1.
Posted Mar 03, 2011 · 06:24 UTC#6
Bluetooth module for the Z3 is decent.
There is no echo and the sound quality is good.
BUT....when you drive on the freeway, it picks up too much road noise and is not too useful IMHO.
But at idle or local roads @ lower speeds, its fine.
Posted Mar 03, 2011 · 06:53 UTC#7
If some 1 call you and u opened bluetooth and some 1 in ur car and dont want them to listen to the conversation can u pick talk on cell phone instead or u cant pick?
Posted Mar 03, 2011 · 12:14 UTC#8
Your phone should have an option to "tranfer call" to handset. I have done this with both blackberry and iphone.
Posted Mar 03, 2011 · 15:44 UTC#9
You have to jam down the volume buttons which either did or would not work. They were checked out by Frod as fully working but who really knows. The Pioneer remote solved the problem
Posted Mar 04, 2011 · 04:41 UTC#10
Thanks. thats the only question about getting the bluetooth, cuz i heard u cant use ur phone when u have bluetooth on.
