Where is everyone installing the antenna for the gps? i know the dash is popular, but where else is appropriate?
J
Posted May 22, 2006 · 15:02 UTC#1
solrackm said:I put mines in front of the sunroof.
Tyrant11429 said:What about on the windshield in the corner on the inside of the car like a car alarm antenna ?
maxse said:Guys any1 mount it under the front dash? Im getting mine installed soon and the installer says that both XM and GPS will be fine underneath the front dash.
cntrylvr79 said:maxse said:Guys any1 mount it under the front dash? Im getting mine installed soon and the installer says that both XM and GPS will be fine underneath the front dash.
That's news to me. I have never had either antenna work properly mounted under the dash of any car. They need at least a line of site to the sky to work, be it through a window or outside. I'd seriously think about getting it installed somewhere else. Sounds like the installer is trying to be lazy
03Aviator said:cntrylvr79 said:maxse said:Guys any1 mount it under the front dash? Im getting mine installed soon and the installer says that both XM and GPS will be fine underneath the front dash.
I have TWO vehicles with XM antennas under the dash and one with GPS under the dash. They work perfectly with maximum strength signals. Two things you need to do. (1) Make sure there is no metal above your antenna. (2) make sure you affix the antenna to a piece of metal. You can cut a piece of sheet metal about 3" by 3" and mount that with adhesive, velcro, etc. Then just stick your antenna to the top of it. I promise you that you will be very satisfied and you won't have an external indication of what's in your car.
edrock200 said:What is the 3x3 piece of metal suppose to do?
03Vic-HPP said:It provides a ground plane for the antenna.
03Vic-HPP said:Actualy the ground in "ground plane" doesn't refer to an electrical ground, so the metal plate does provide a ground plane
http://en.wikipedia.org/wiki/Ground_plane
