Ok peeps kinda a weird wire question here.. im looking for a Clip its the OEM clip to the radio but i need this clip in Raw forum.. Just the Plastic and un-crimped pin's so i can put what wires i need in the right spots. Basically making a custom radio harness.. im fairly decent at installing but don't know anything about finding Custom parts.. its tight behind this radio in the MS3 so i figured i would try to attempt a custom harness if i can find the resources instead of splicing two harnesses together. i would appreciate any help. i don't even know what the raw forum would be called "wire harness clip"? or Wire harness terminal"? not sure. here is a pic of the exactly what i need but this has the wires installed already.
Thanks in Advance
