Howdy everyone, I just installed a d3 in my 2000 jetta tdi and relied heavily on the search function here and some trial and error to solve the majority of the problems so I thought I would post those problems and solutions here in case someone else encounters similar situations.
Items used and where purchased.
avic d3- eBay
BTB200-eBay
i200 (5v hack)-ebay
gps cable+antenna-ebay
adt-va133-amazon
wiring harness for jetta- best buy
I installed the system using the pioneer adt-va133 which fits the dual opening of the jetta but you have to push REALLY hard, and do a little bending. If you're ok with the head unit kit sticking out any extra1/8 of an inch, then you don't need to do anything to it, but if you want it to be more or less flush with the surrounding you have to bend the wings on the outside of the cage and slide it back into the opening a little bit extra. It's still not perfect but it looks a bit better.
Issue #1- why doesn't this f-ing cable charge my iphone?!
So I was bench testing the unit to make sure it booted up ok, and decided to try out the ipod 5v cable on my iphone, while it did allow the d3 to see my phone it did not charge it. this was a huge bummer because I thought that was th point of having a 5v i200 cable. I solved this problem by pulling a 12v lead directly off of the wiring harness and running it to the "box" that contained the 12v to 5v step down circuit board (it's built into the cable about 18" away from the base allowing you to hide it and still have about 36" left to pop out from behind the dash/center console). I didn't expect it work, but low and behold the phone charged and the d3 recognized everything. I'm not sure if the initial lack of charging was due to a fault of the connector on the cable or the power output of the d3 but giving it a direct 12v feed worked great. Note: I decided I'd be "smart" and pull the 12v lead off of the red wire which I believe is the "battery" wire so that I could leave the phone charging with the camera off, not only does it not do that, now if I leave the cable connected to the iphone and turn the car off and pull the key out the radio stays on, I'll most likely change that over to the yellow "alternator" feed in a couple of days when I hook up the vss and reverse wire.
issue#2- Why does the "mute" tag pop up, Why does the gps think I'm in brooklyn/los angeles? What did I screw up on the bypass?
I did a search and looked up all of the information and read (keyword read) all of the stickies on this site. I found some people that had similar issues but their fixes didn't work. It wasn't until I clicked on the flash guide that I discovered (what I assume to be) the issue. It turns out that the person who owned the d3 before me had already done the bypass so when I swapped the mute cable I was in fact putting it back to where it was originally located. So when I swapped the mute cable (a second time) suddenly everything worked great. I don't know if this is directly linked to the gps issue (it kept telling me I was located at the default east or west coast starting locations. but as soon as I swapped it the gps found me (i'm in the southeast) So for those of you that pick up the d3 on ebay and it comes with a wiing harness, double check the sticky that has the flash guide, and make sure that the bypass wasn't already done, cause you'll feel really stupid if it was.
issue#3 Why the f- doesn't my iphone pair with the system?
Well it turns out the guy who owned the btb-200 before me changed the default password (somehow) so after 15 attempts at pairing I decided to hit the reset button (well hold down the reset button) and sure enough the default passcode worked and the iphone paired no problem. IN fact everyone I've spoken to says that I sound clearer through the btb-200 then I do just talking into the phone, which is pretty cool.
issue#4 Why the f- do I have to keep pairing my iphone with the d-3?
I totally didn't realize that the phone had to be registered after it was paired for it to auto-connect when you get in the car. I dId that and sure enough the car picks up the call as soon as you turn the car on.
Issue #5 Why can't I watch video on the d3 through my iphone?
Cause apple sucks. I remember with the old 3g I had I hooked it up to an alpine head unit and was able to see videos from the phone, and videos from youtube. Well some time since then apple released a "firmware update" that kept video from coming down the line of the dock connector. This sort of pissed me off, fortunately there are people out there who are talented at making things work "better". So I jailbroke the phone (which I was extremely hesitant to do but surprisingly easy i used "green poison") and downloaded resupported 4. It's perfect and I love it. Best 4 dollars I've ever spent.
Issue #6 How can I set the phone to default to bluetooth for phone calls but dock connector for music?
I uh, still haven't figured that one out. When I get in the car and hook up the iphone to the car the music plays for about 3 seconds until the phone autoconnects through blue tooth then I have to pull up the ipod app on the phone and change the output to "dock connector" but doing that resets the phone, so when you get a call it doesn't go through the d3. It stays on the "iphone" option when speaking then you have to click on the d3 bluetooth option. It's super annoying and seems like it should just be an option in the phone but I can't for the life of me figure out where that selection is if it exists.
Issue#7 Why can't I sync my phone book?
Yup I can't sync my address book, I even downloaded the avic app from the app store but I haven't figured that out yet.
Anyhow maybe this helps someone else out most of the problems seem to come about because I bought my stuff used off ebay but since this head unit and items are kind of old I think there will be more "new" owners that are buying there stuff used and perhaps encountering similar problems.
Anyhow I've had the system installed for a couple of days now and I'm angry at myself for not doing this install sooner, I totally love it.
