I have the F900BT and its been upgraded to the 3.x firmware and working for months. I decided to try and add the following mods:
- software speed bypass
- larger clock on map screen
- buttons to toggle route TTS (voice)
I've got a problem with the data.zip though. If I uncompress it using the terminal and then recompres it, from the extracted directory, using:
zip -r ../data.zip *
It creates the archive fine, but when I copy it to the APL2/iGo folder and restart, then unit just hangs at the starting up message. Replacing the data.zip with the original one returns everything to normal. The layout of the archive is correct, ie it doesn't contain a top level data directory.
Has anyone done any mods with a mac that can help explain what is going on?
