got it, thanks
avh-p4300dvd bypass
yes it is!
i got it all working now.
iphone is the only problem now
Hi, i cant see how do you make the bypass please someone can explain
thanks
So wouldn't grounding the Parking Brake wire do the same thing? Or is there another reason for the relay?
Has anyone had any trouble accessing the root menu on the unit after installing this? I calm still capable of watching movies, but I can't access the root menu. I'm needing to get to this so I can set up my iu200v cable.
I installed the brake bypass but cannot acces menu when the unit is powerd off because the brake bypass is powered by the remote wire so i called a few places and a pioneer installer told me i could try to leave the brake pass installed but detach the brake wire from the by pass power off the unit and tap the green brake wire twice angainst a ground and it should let you have acces to that sub-menu, anyone else heard or tried this please let me know
