Alright fellas, so here is my issue; I did the bypass on my Z110 and everything worked fine for a few days, all of a sudden, I received the infamous message about the parking break lead not being connected. I knew my connection were done right because I double checked everything before installing and I soldered all the connections.
I figured my ground was not connecting properly so I tried it at a different location and the message still kept coming up. Well after looking through the forum and seeing the problems that others had, I figured the connection of my mute wire was not making a solid contact. Well I pushed the pin in as much as I could and tried it out and that was the issue. Problem fixed right??? Not at all, for some reason it keeps coming loose and I already crimped the wire close to the pin because of me trying to push it in so many times.
Has anyone else had this problem, is there a way of strengthening that wire without me having to pull the whole harness out? I figured trying to add solder to it to give it a little rigidness, but it seems risky?
Any advice is appreciated!
