bypass and parking brake wire
By hluecke · Feb 28, 2011in Hacks/Mods💬 3 posts👁️ 2,307 views
Posted Feb 28, 2011 · 17:21 UTC#1
i installed an X920BT after moving the mute wire one pin to the left on the AV harness. i ran the other end to ground, and then connected the light green parking brake wire to the brake sensor (perhaps a mistake)
the bypass isn't working (functions disappear when brake is off), so i am wondering if this is likely due to a bad connection on the mute pin, or if actually connecting the parking brake wire has screwed up the bypass. i gather from previous posts that the parking brake wire doesn't need to be connected to the brake, but i also haven't seen any indication that it shouldn't be connected.
any help is greatly appreciated!
Posted Feb 28, 2011 · 18:04 UTC#2
You want to ground the parking brake, not connect it.
Posted Feb 28, 2011 · 20:09 UTC#3
got it...thanks!
