Hey Everyone,
I recently put a 920BT into my 09 Smart ForTwo Passion. The vehicle came with the double Din in dash 6 CD changer radio with 5 speakers. For the most part the unit is great. The major problem I'm having is with the nav.
For the life of me I couldn't figure this issue out. I picked the car up at night from the installer & Nav unit showed me within 50 meters of the store, which the salesperson told me was average due to the unit not finishing it's calibration. Once on the freeway the unit worked perfectly, lane guidance, turns, just about everything. After leaving the freeway the unit was at least 5 blocks off where I actually was. In addition to that, when I was "stopped" the unit showed my vehicle continuing to move through streets, jumping blocks left & right. Initially I thought the unit was struggling with Satellite reception and since it was extra rainy & cloudy that night I thought that added to the signal issue. The next day the rain was gone, and I went out to my car to configure a few more items, I jumped in the car booted up the unit, and there I was moving through the streets while parked again. I also get the stock warning about the Parking brake ground being improperly installed?
Working through some trouble shooting on my own I've figured out the following. If I'm on the move, and I physically turn off the headlights, the nav unit thinks I've stopped. If I notch the emergency brake up just enough to engage the light, I have all the menu's unlocked so I can change all the settings from the top menu. Very odd. In order for the Nav to work correctly in town, I have to turn off my headlight switch everytime I come up to a stop or traffic light in order for the nav unit to see that I have in fact stopped. The other closely related issue is that the Day/night dimming feature isn't installed. I have to manually adjust the display each time between day and night. Ugh. I expect a little more for a 1K av unit.
Any suggestions?
