I have a Blackberry torch, is there any way to stream music from your phone to your Avic 900bt? I hace alreay tried the front av jack to the head phones. Dosent work. Any suggestions?
Thanks < Emery
Thanks < Emery
Did it try sinking it with Bluetooth? Not sure if it works or not .. Someone correct me if I'm wrong
Sadly, the F90/900/700BTs don't support the A2DP profile you need to stream music. It can only be a speakerphone and a serial port, thanks to the version of the Parrot chip Pioneer used.
Oh, and the front jack should work, as long as you have enabled the AV2 input. You'll see a message not to view front seat video on the screen when you use AV2. It's how I do Pandora with my Droid2.
