I have 2 4x6" 2-ways in the dash (polk db461) and 2 6.5" 2-ways in the front doors (DB561)
The amp I have has 2 HPF channels @ 40w RMS each or 1 @ 100w RMS.
If I run 2 speakers on the head unit, and 2 on the amp, I have to turn the amp all the way down to get any sort of volume leveling between the 4, otherwise, it's just the dash speakers overpowering the door speakers.
I was wondering if 2-ways are even worth putting on an amp at all?
The f700BT has a 3 band parametric EQ with 12 total frequencies adjustable as well as a built in high pass filter - which makes me wonder if I would even notice the difference at the same volume vs putting them on the amp...
Any ideas?
I plan to get components as soon as possible, know that I know how good they are, but for now, I want to use these.
Side note: is it bad to run the speakers from the head unit? what about vs running all speakers on amps? will it last longer if I don't? Will it get hotter if I do?
