Installation Problem of 920BT on a VOLVO S80 2001
By limzinfo · Mar 08, 2011in Problems/Troubleshooting💬 12 posts👁️ 2,832 views
Posted Mar 08, 2011 · 17:56 UTC#1
hello everyone,
i have been tying to build a 920BT in a Volvo S80 2001. The Radio and sound works, but I can not find the pin for conecting Steer Wheel Controll, Reverse and Speed Controll. Is there someone, who knows the solution?
Thanks a lot!
Posted Mar 16, 2011 · 02:27 UTC#2
up, no one knows?
Posted Mar 16, 2011 · 17:59 UTC#3
DirecTech's has nothing listed, sorry
the reverse wire can always be found at the back up light harness if nowhere else, and since the camera goes back there, its not really out of the way.
Posted Mar 18, 2011 · 14:19 UTC#4
Unfortunately Volvo has that info you need in the Can-Bus network. A british company Connects2 offers a Can-Bus reader for many european brands but they do not list the S80 is a model that is applied. However, it does work on some other models. I have not found a steering wheel interface for any Volvo model that uses Can-Bus for communication between the radio and steering wheel. You can get away without using VSS on Pioneer's AVICs and still achieve simple Hybrid mode. Good luck.
Posted Apr 10, 2011 · 23:44 UTC#5
hi S157,
"You can get away without using VSS on Pioneer's AVICs and still achieve simple Hybrid mode. " excuse me, i don't unterstand, what dose it mean?
Posted Apr 12, 2011 · 15:28 UTC#6
it simply means that you dont HAVE to have the VSS wire connected for the nav to work, it will function fine with out it.
Posted Sep 22, 2011 · 11:26 UTC#7
Hi, thank you for your tip, do you know how can i connected the button on my 920bt device?
Posted Sep 22, 2011 · 18:01 UTC#8
what button are you trying to connect?
Posted Oct 27, 2011 · 00:02 UTC#9
so first the Speed Signal. Where schould I conect the speed Signal?
the secend problem is How can i let the steer Wheel control, there is not a direct conection between the buttons and the Device, is it?
thanks for the answer ^^
Posted Oct 28, 2011 · 22:33 UTC#10
well since no one has any info on where this wire could be, you have two options, A: start poking around with a meter until you find it or B: dont hook it up.
well since PAC has nothing listed on there website, and metra doesn't list a module that is compatible with the car, it looks like you are probably SOL on getting steering wheel controls to work with that radio.
Edited Oct 28, 2011 by 1loudls
Posted Oct 28, 2011 · 22:47 UTC#11
alot of times the speed sensor is located at the Cruise Control
and alot of times there is also a speed sensor wire located in one of the harness's that go into the dash cluster
something you could do is just stop in Best Buy and ask one of there mobil install ppl if they could look it up for you they have access to all of this stuff atleast they did for 3 of my cars that i had to find out where it was
Posted Oct 29, 2011 · 21:09 UTC#12
already check all that software for him, as mentioned before, nothing is listed.
the problem could be that if that car is new enough to have a CAN system instead of ODB, then those signals would be transmitted through the CANbus, and not through a dedicated line.
