How to make sure a USED headunit is fine ?
By Danv · Mar 19, 2011in General💬 5 posts👁️ 1,445 views
Posted Mar 19, 2011 · 18:24 UTC#1
I've been in contact with a guy wiling to sell his old Pioneer AVIC F700BT.
Can you guys tell me what's suppose to come with it and how can I verify if everything is in order ?
Do we have to install it back in his car ? Or there's a way to fire up this thing without being in a car?
Thanks for your help
Edited Mar 19, 2011 by Danv
Posted Mar 19, 2011 · 19:02 UTC#2
You can use a PC or other power supply, just connect GND and +12v and test to your hearts content
Posted Mar 22, 2011 · 17:05 UTC#3
you should get the main unit, the wire harness, the AV harness (harness with a bunch of RCA plugs on it), the GPS antenna, and the microphone to make everything work.
Posted Mar 22, 2011 · 17:07 UTC#4
Thanks for your help guys! :)
Posted Mar 29, 2011 · 19:03 UTC#5
Plugged it in my old computer yellow in yellow, black in black and red in yellow. Also had to plug the light green into the ground to do the bypass !
Tested and I'm happy :) I hope I'll be enable to install it soon ! :)
