Z130BT Upgrade Hacking
By ShortFuse · Mar 22, 2011in Hacks/Mods💬 22 posts👁️ 19,092 views
Posted Mar 22, 2011 · 19:03 UTC#1
Has Pioneer even confirmed they will release an upgrade? Crack is already done...
I'm just waiting for the SDs
*PS: Mod, don't lock. This is a placeholder and I'll rename and update this thread once things start releasing
Edited Mar 22, 2011 by ShortFuse
Posted Mar 22, 2011 · 19:39 UTC#2
So you have already cracked the 130 software? I don't understand. And yes, we know there will be a 130 upgrade for older units.
Posted Mar 22, 2011 · 20:35 UTC#3
The z120BT to z130bt update method is cracked.
I have a fake v2.004 that runs on Z120BT that will accept any upgrade in the SD. I need to test before it's public (of course)
Posted Mar 22, 2011 · 23:43 UTC#4
Wow, you're the man.
Posted Mar 23, 2011 · 02:20 UTC#5
I haven't heard anything myself. This is awesome news. I'm a little late to the upgrading game. I just upgraded my 110 to 120 a few days ago and this would be perfect timing for me to upgrade to 130 now.
Posted Mar 23, 2011 · 15:26 UTC#6
not sure when pioneer released their Z120 FW update last year, I think it was around june/july.
Posted Mar 23, 2011 · 21:05 UTC#7
That's pretty awesome...
I was wondering if there would be one as well, given the difference in hardware(built-in HD Tuner)...
You freakin' rock!!!
Posted Mar 24, 2011 · 00:16 UTC#8
Shortfuse,
I'm not the expert here, but from what I understand of your method, it seems like it would be pretty easy for Pioneer to defeat this crack, if they wanted to. Just refresh the patched files with the originals before continuing with the update.
So, since no one has seen the Z130 update, or is even sure what it contains, it may be premature for people to start with the hi-5's.
But I sure hope you have it nailed.
Posted Mar 25, 2011 · 05:23 UTC#9
Shortfuse,
I'll reverse engineer it if they do.
I wonder though, While I know that the Z110BT can be upgraded to 2.000, is it running the same EXACT files as the Z120BT is running?
It could be possible to make package our own update by using testmode to dump the Z130BT file and flashing it ot the Z110BT/Z120BT
Edited Mar 25, 2011 by ShortFuse
Posted Apr 13, 2011 · 02:28 UTC#10
The Z130BT upgrade software is the same I am running it on my Z120BT
Posted Apr 13, 2011 · 03:55 UTC#11
The Z130 software is 3.00 and it's not out as an upgrade yet.
Posted Apr 13, 2011 · 16:05 UTC#12
I've got F30BT with 3.000 fw, but i can't access to explorer via testmode.
I could make a copy 'my flash disk', if there was an option to get working testmode for f30bt.
br
condi
Edited Apr 13, 2011 by condiczek
Posted Apr 14, 2011 · 14:54 UTC#13
br
condi
We need to find that testmode. Are you sure it doesn't work? Have you done it before on a Z110/Z120?
Is there any manual available?
Posted Apr 14, 2011 · 20:20 UTC#14
I haven't done it on Z110/Z120. It's my first AVIC, but I was working with many gps devices in my work,
made many mortscript scripts etc. Windows CE is familiar for me.
I'd like to help as much as I can :)
I will have more time to check all service testmode discs etc, over the weekend.
What about GGS1080, GGV1345 or maybe some newer version?
Testmode 2.3 of course is not working.
http://www.schematics.me/purchase.php?id=Pioneer+AVIC-F30BT%2FXNEU5+Service+Manual+%2F+Schematics
hmmm.. fake?
interesting thing:
http://www.zeroplus.com.tw/software_download/Protocol%20Analyzer%20SD%20Introduction..pdf
http://www.jinvanisystech.com/sd_sleuth_pro.html
Maybe there would be a good solution to use some logic analyzer, something which could give as the key-filename to the testmode?
Pioneer device when booting - search for testmode executable, then check for the proper blank key-file, and grant access :>
Am I right?
If we could get some logger/analyzer on the SD or maybe USB device, than we could sniff it?
One more:
http://www.robotshop.com/sfe-sd-sniffer-1.html
Edited Apr 14, 2011 by condiczek
Posted Apr 19, 2011 · 11:56 UTC#15
Any updates about this Hack?
Posted Apr 23, 2011 · 20:14 UTC#16
My adventure with F30BT :D to be continued here :)
Edited Apr 25, 2011 by condiczek
Posted May 04, 2011 · 00:34 UTC#17
Hey ShortFuse, any progress on this? I have the Z120 and Pioneer will not have an update for it until late this year. I'd love to upgrade to the 130 features if this is possible!
Posted May 04, 2011 · 11:05 UTC#18
Finally
Thanks Condi
i tested in my z110bt, its worked , now i can use IGO 8, my commnent are at
Original Condi´s Hack My link
Thanks Man ,
Let´s Hack !!!
Posted May 04, 2011 · 18:02 UTC#19
Finally
Thanks Condi
Thanks Man ,
Let´s Hack !!!
OK read the link but it does not list the AVIC-Z120BT as campatible. Can anyone confirm that this works on the 120?
Posted May 04, 2011 · 23:35 UTC#20
It does.
Posted May 06, 2011 · 11:54 UTC#21
i Notice something , when i press the voice (vr) button in my unit z110bt upgrade to 120 , it ask to call map and press button again, when i in map and press its start vr function, maybe whe can search for the VR executable (probably \pr0\apl\voice.exe)and change with Av.exe from condi´s hack, and find a way to back to Windows ce into running system! or call a new app asking for hack mode or start VR!
Edited May 06, 2011 by PatrickFernandes
Posted Sep 24, 2012 · 13:42 UTC#22
Any upgrade for z120 to a Z130?
