Buick Enclave Steering Wheel Controls & Z130
By drewmich · Mar 22, 2011in Problems/Troubleshooting💬 4 posts👁️ 1,104 views
Posted Mar 22, 2011 · 19:22 UTC#1
Have a new 2011 Enclave and just bought a new Z130BT and I am being told that neither PAC or METRA have any adapters that allow for use of the steering wheel controls on the Z130??
I hope this isn't accurate as I really like the Z130 but have to have steering wheel controls.
Posted Mar 23, 2011 · 07:10 UTC#2
I would give Crutchfield, PAC, and Metra a call, see if any of them have tested the car yet.
Posted Mar 23, 2011 · 12:25 UTC#3
It might be that since the unit is so new, they just haven't listed it yet. There are physical differences from the Z110/Z120, so maybe they aren't announcing support until it can be thoroughly tested.
Posted Mar 23, 2011 · 16:24 UTC#4
Easy fix. Metra's ASWC universal steering wheel interface works awesome! They don't show any information on it on their website, but it is definitely do-able. We did on on Monday with the Z130BT and it works perfect.
use the pink wire from the ASWC to the Dk. Green wire of the radio harness (data), and simply red to ACC, BLK to GRD, and when you turn the accessory to the on position, hold the volume button on the steering wheel "UP" until the unit recognizes it. The l.e.d. on the ASWC will light up solid red when it discovers it.
literally a 5 minute install.
The PAC unit works OK, but takes the factory buttons on the Enclave out of order, and you can only go up with presets or tuning, not down at all. (sucks).
Good Luck!
WestEnd Audio
