Hi i've searched the forums and i couldn't find a fix to my particular problem. When i turn my unit on the screen is black , the buttons light up for about 15 or 20 seconds then go black,but you can hear the fan running constantly. I tried doing a reset , that did nothing. Some one please help.
avic f90bt wont boot
Try this: http://avic411.com/index.php?/topic/30828-boot-problemsblack-screen-fixrestore/
This problem is common on the f series units...... Imo its a piece of junk
get rid of it and buy a different brand (pioneer is junk/horrible customer support)
...so i tried to do step.6 but i couldnt find that option. does it matter that the steps are for a f900-bt
Its the same f90bt and f900bt are basically the same unit....
Remember do not install sd card until ufter step 6. Up until then leave it out..... Once u finish step 5 insert the sd card and leave it inserted until u are ready to reboot to 3.0 update basically leave it in until u are completely done with all the steps. Hope it works
Sorry i meant do not install sd card until after step 5, when u do step 6 u need to have the sd card in.
ok when i do the upgrade (format) it reads the files up to 100% but it doesnt do anything else. no write image no reset unit
Hmm after it reads 100% itll take a minute or so then it will say RESET...... after u reset thats the step where u will need to go to test mode and rewrite the flash disk
I let it sit up to 40 minutes One time. Ive done it multiple times.
help my f90bt wont let me upgrace wince it resets before it can complete
