USB OR SD CARD locking unit up when playing mp3
By nelldanator · Mar 25, 2011in Problems/Troubleshooting💬 3 posts👁️ 861 views
Posted Mar 25, 2011 · 13:04 UTC#1
every time I try and play MP3's either by sd card, or usbflash disk, it will lock the unit up. If I have more than 12-15 tracks, it will not even load the list, or let you change songs. Heres how it goes, I plug in usb, it loads a list, select a song, and it starts playing, somtimes I can change the song once, or maybe twice, then it will lock up the unit, I can't adjust anything other than the volume, it will play out the remainder of the song and then dead air. Only way out is to kill ignition, or reset.
Posted Mar 25, 2011 · 19:44 UTC#2
I wonder if a file is corrupted. I'd check the card and the USB with my computer like I'd check any other drive. Then, I'd format either/both in FAT32 or 16, as the head unit can handle. I run HD in one car but only (either) FAT file system works. Your unit may have a capacity restriction, too.
Posted May 06, 2011 · 03:36 UTC#3
upgraded to 3.0 software, problem solved !!!
