Help!! I can not delete!
By silverbullet911 · Mar 26, 2011in General💬 7 posts👁️ 2,322 views
Posted Mar 26, 2011 · 06:25 UTC#1
I had a Z120BT installed recently and I'm trying to delete a registered bluetooth device. I have reviewed the user manual and it only refers to deleting a device if you have reached the maximum of 5 device and wish to add another. Please help! Thanx.
Posted Mar 26, 2011 · 12:28 UTC#2
The only way to delete a BT pairing is to do a full reset of the AVIC (or pair 5 more devices). See pg 186 of Z120 manual.
Posted Mar 26, 2011 · 14:36 UTC#3
You don't really need to delete them, it doesn't hurt anything.
Posted Mar 26, 2011 · 15:46 UTC#4
Thanx. Done...great forum!
Posted May 02, 2012 · 18:51 UTC#5
Is this the way to delete phones on the z130 also?
Posted May 02, 2012 · 18:55 UTC#6
Yes as well as all units in this series.
Posted May 02, 2012 · 19:00 UTC#7
The reason why this actually needs to be an option is if there is some sort of issue with the paired phone that a delete and re-pair would fix. When I owned these units I had issues at times with the phone connecting as both handsfree and A2DP. Sometimes it just wouldn't work and the only solution was to delete and re-pair. But because you cant do this with these units it required a reset of the whole unit. It is a stupid software design and has been a problem sense the 110. The F/1st gen X series did not operate this way and at least in this regard, was easy to fix if you had this problem.
