I am planning on buying the 130 this week and i want to make sure my steering wheel controls work. I have a Prius so i dont have that many buttons. What would be the unit i should get i know pac has a few. What would work best with the 130 and my prius.
With pac you end up buying 2 or more adapters one that works with particular radio one that works with your particular car and some other adapters for power and amplifier, there is one and only one box solution that detects you radio and car at the same time:
http://www.youtube.com/watch?v=vUNkLvpxWIc
http://www.axxessinterface.com/steering_wheel_control_new.aspx
You still need the actual power/speaker harness...the aswc is just for steering wheel controls.
What year is the Prius?
i have a 2008 prius.
I want to buy the device off of amazon if possible so a link to what I should get would be much appreciated.
I am not too familiar with any of this I am taking it to a shop to install all this but i thought it would be cheaper to buy everything on my own rather than from them.
If you could explain what it is i need so that I will be able to keep my steering wheel controls.
thanks
For steering wheel controls you can use:
http://www.amazon.com/Metra-ASWC-Universal-Steering-Interface/dp/B0039H2W66/ref=sr_1_1?ie=UTF8&qid=1301191965&sr=8-1 along with wiring kit 70-8114 which I can't find on Amazon.
or
They both do the same thing. The ASWC is much easier to install, but I'm personally a fan of PAC modules.
You'll also need a power/speaker harness. If you have the standard audio, you just need this adapter: http://www.amazon.com/Metra-70-1761-Wiring-Harness-Speaker/dp/B0002BEQJ8/ref=sr_1_1?ie=UTF8&s=electronics&qid=1301192582&sr=1-1
If you have the JBL package, I'll have to do some looking.
thanks i dont have the jbl audio and im not doing the install myself im taking somewhere and they will install im just buying the parts otherwise it would be like $100 from them when i can get it for much less at amazon plus i have an amazon gift card
