F920bt - navgate feeds grayed out not selectable
By Hagstrom88 · Apr 01, 2011in General💬 1 posts👁️ 1,449 views
Posted Apr 01, 2011 · 20:07 UTC#1
* SOLVED *
Took me 7 hours to figure it out. Decoding a dutch site that solved part of the problem.
1. Do not use an old sd card that you might have used before unless a) you reformat it it, ie ereasing everything on it in windows. You do it by rightclicking on the removable disk displayed in windows under My Computer.
2. With the fresh sd card (empty) put it into the navigator and switch on the navigator. Eject the card and bring it to your pc once again.
3.I then used navgate feeds on the pc and stored some pois. Saved them to the card - brought it back to the car - started teh navigator and it worked.
Caution about navgate feeds if you Import pois from a csv file. I thought the csv file should contain Wgs84 coordinates but it didnt work. Your csv file should contain Decimal coordinates to your POI:/s (i guess it converts them to wgs84 When it saves the qfile to the sd card as a KML FILE.
The csv file should look like this before you open it in Navgate feeds
"13,43434","59,4354", "my grocery store"
Row 2 and so on
My problem was also that in some countries, like mine, coordinates look like this "13.43434" (period instead of comma) - This navgate feeds accepts but the saved KML file will be screwed up and when you select to go to you grocery store it might asknyou to board the ship to Africa!
***** Problem ********
Hi, greatful for any help on this. Got my unit today. Everything is fine, changed my splashscreen etc. Downloaded Navgatevfeeds to My pc and
saved some kml poi lists on the sd card. Im stuck - how do i access the pois on the sd card? On my unit the option is grayed out and not even selectable!
Any help appreciated. Thomas
Edited Apr 02, 2011 by Hagstrom88
