Hi.
I looked all over this site and couldnt find any wiring schem. how to bypass every Pioneer AVIC, AVH and dvd recivers. So here it is.
I choosen to use two relays for more practical issues like wiring extra amps, power antennas and much more. I also added a fuse for safety and if you wih to connect several amps. If you connect several amps directly to the remote wire from HU, you will propably kill the remote circuit in your HU.
This is how it works:
1. You turn on your HU
2. Remote signal will activate relay 1
3. Relay one will close the switch so you get current from battery, through a fuse and to amp, antenna ++
4. At the same time, relay 2 will also be activated
5. Relay 2 will close and ground the park. brake wire from the HU.
Easy as that.
Hope you guys find this wiring schem usefull. ![]()
To mods: i didnt know where to put this ass this covers most of the pioneer HU.
